bongolan
May 30, 2017Aspirant
Boot stuck at ready
- May 30, 2017
it suddenly work, we're already backing up the files and will decomission the server. thanks
mdgm-ntgr
May 30, 2017NETGEAR Employee Retired
I think it's the backup button you need to press though the 3200 doesn't have a backup button. You might need to hook up a VGA keyboard enter the BIOS and get it to do the next boot off a connected USB device.
I think the syslinux version for USB Boot Recovery may be newer than the one on the internal flash which could be how you can tell if it's booting properly off the external USB.
bongolan
