sebastianci
Jun 30, 2020Aspirant
btfrs_root_node 38
Today I fiorst staterd to get info that my nas is write protectected when tried to write , the I have powered it down from web interface. After that NAS does not boot , instead on display I am getti...
Jul 03, 2020Guru - Experienced User
sebastianci wrote:
Can you help with further steps for btrfs recovery?
I haven't needed to do it myself, so it's not something I can give much guidance on.
I can say that you should start in tech support mode with
# rnutil chroot
That will both start RAID and chroot.
If for some reason, you only want to start RAID, then with OS-6 you'd enter
# start_raids
(not start_raid)
If you have ever expanded your RAID array vertically, you probably will need to enter
# btrfs device scan
This shouldn't hurt if you don't need it.
If you want to try to mount the volume, the normal command is
# mount /dev/md127 /data
But most BTRFS repair tools can't be run on a mounted volume.
You should read up on btrfs check --repair and maybe also btrfs restore
sebastianci
Jul 03, 2020Aspirant
Great thanks
It is good starting point i will do some reading, just to make my work easier: how to gracefully shutdown NAS in tech support mode, shall I run something to stop RAID, I guess I just exit from chroot. How to shutdown NAS then, shutdown command does not work?
- StephenBJul 03, 2020Guru - Experienced User
# shutdown now
should work. Are you sayng it doesn't?
- sebastianciJul 03, 2020Aspirant
Yes
# shutdown now
-sh: shutdown: not found - SandsharkJul 03, 2020Sensei
Try rn_shutdown. That's an r & n (for ReadyNAS), not an m before the underscore. That's the command for standard SSH, I have never tried it in tech support mode. It's located in /usr/bin.
- sebastianciJul 12, 2020Aspirant
Hi sorry for delay. To minimise interactions with my NAS , I was waiting for new HDD.
Now I started and not sure why my nas is md126, see attached screenshot.
Unfortunatelly btrfs commands do not work on md127, md126 checksum incorrect.
Can you say if md126 is an sensible raid alias or i need to rearange something?
Sebastian
also, rn_shutdown is also not present ?
- StephenBJul 13, 2020Guru - Experienced User
Your NAS was vertically expanded (disks 1 and 3 appear to be larger), so you have two RAID groups. Normally md127 would be the original group. But in your case that appears to be md126.
Have you given up on Netgear tech support? They should have gotten back to you by now.
You appear to be missing several commands that you ought to have. shutdown should be in /sbin; rn_shutdown should be in /usr/bin
Did you start with
# rnutil chroot
Or did you skip that?
- sebastianciJul 15, 2020Aspirant
Thanks for answer,
On the subject of btrfs, thanks: md126 it is.
Mounting as ro does not work : btrfs_root_node+38
Running check --repair:
root@3EPB43EE0025E:/# btrfs check --repair /dev/md126
enabling repair mode
checksum verify failed on 9150299111424 found 10BC57A5 wanted 18B79090
parent transid verify failed on 9150299111424 wanted 88714 found 86890
Csum didn't match
ERROR: cannot open file systemI know you not an expert on btrfs, though any suggestion might put me in right direction.
On netgear tech support
They contacted me origianly, spent 45 minutes on the NAS and decided I need to pay ~£160/hour for data recovery - of course no guarantee.
I am afraid they either want more hours, or recover partial data which does not contain what I have really lost. I accept I will loose 2 weeks of family pictures, so be it.
On shutdown
In chroot I can see both files
/sbin/shutdown
/usr/bin/rn_shutdown
issuing rn_shutdown: causes some noise from disks and nothing happends,
issuing shutdown: "Running in chroot, ignoring request"
After typing "exit", rn_shutdown, shutdown are no longer present.
If I run new telent also rn_shutdown, shutdown are not present unless I enter chroot
Thanks
