sebastianci
Jun 30, 2020Aspirant
btfrs_root_node 38
Today I fiorst staterd to get info that my nas is write protectected when tried to write , the I have powered it down from web interface. After that NAS does not boot , instead on display I am getti...
Jul 13, 2020Guru - Experienced User
sebastianci wrote:
Now I started and not sure why my nas is md126, see attached screenshot.
Unfortunatelly btrfs commands do not work on md127, md126 checksum incorrect.
Can you say if md126 is an sensible raid alias or i need to rearange something?
Your NAS was vertically expanded (disks 1 and 3 appear to be larger), so you have two RAID groups. Normally md127 would be the original group. But in your case that appears to be md126.
Have you given up on Netgear tech support? They should have gotten back to you by now.
sebastianci wrote:
rn_shutdown is also not present
You appear to be missing several commands that you ought to have. shutdown should be in /sbin; rn_shutdown should be in /usr/bin
Did you start with
# rnutil chroot
Or did you skip that?
sebastianci
Jul 15, 2020Aspirant
Thanks for answer,
On the subject of btrfs, thanks: md126 it is.
Mounting as ro does not work : btrfs_root_node+38
Running check --repair:
root@3EPB43EE0025E:/# btrfs check --repair /dev/md126
enabling repair mode
checksum verify failed on 9150299111424 found 10BC57A5 wanted 18B79090
parent transid verify failed on 9150299111424 wanted 88714 found 86890
Csum didn't match
ERROR: cannot open file system
I know you not an expert on btrfs, though any suggestion might put me in right direction.
On netgear tech support
They contacted me origianly, spent 45 minutes on the NAS and decided I need to pay ~£160/hour for data recovery - of course no guarantee.
I am afraid they either want more hours, or recover partial data which does not contain what I have really lost. I accept I will loose 2 weeks of family pictures, so be it.
On shutdown
In chroot I can see both files
/sbin/shutdown
/usr/bin/rn_shutdown
issuing rn_shutdown: causes some noise from disks and nothing happends,
issuing shutdown: "Running in chroot, ignoring request"
After typing "exit", rn_shutdown, shutdown are no longer present.
If I run new telent also rn_shutdown, shutdown are not present unless I enter chroot
Thanks
