devos
Jan 14, 2014Tutor
btsync can't save settings?
Hi, I did install btsync and it did work perfect, I did intall the latest version from the dropbox of the dev. Did run it for 2-3 days, then I rebooted the NAS and after reboot btsync forgets the se...
devos
Jan 15, 2014Tutor
I have that one installed.
The troubleshooting steps that I have done:
• factory reset from frontview
• re-install OS from boot menu
• factory reset from boot menu
• made sure that btsync folder have settings so everyone can read and write from it.
• tried 6.1.5
• tried 6.1.6 rc9
Still same issue.
Issue:
Config file is getting reset after rebooting device and also when I restart the application.
Just the setting file, the sync files are still there and it works perfect to sync etc untill i restart or reboot.
• tried 6.1.5
• tried 6.1.6 rc9
Still same issue.
Issue:
