devos
Jan 14, 2014Tutor
btsync can't save settings?
Hi, I did install btsync and it did work perfect, I did intall the latest version from the dropbox of the dev. Did run it for 2-3 days, then I rebooted the NAS and after reboot btsync forgets the se...
devos
Jan 15, 2014Tutor
This is driving me crazy now I even did SSH root in to the NAS and did write: chmod -R 777 /data/btsync . That did not work either.
Does btsync store the config file somewhere else?
I can se it in /data/btsync/config but I want the webUI so I don't want to play around in it.
Edit: Tried to chmod -R 777 on the /apps/btsync folder also, no luck there either.
Edit2:
Here is the permissions on the folder, any suggestion what I should change it to as it might work?
lrwxrwxrwx 1 guest guest 19 Jan 15 08:13 config -> /apps/btsync/config
drwxrwxrwx+ 1 guest guest 0 Jan 15 08:13 shared
drwxrwxrwx+ 1 admin admin 22 Jan 15 08:43 Sync
And please post the command line, my linux skills is kind of out now.
Edit2:
