devos
Jan 14, 2014Tutor
btsync can't save settings?
Hi, I did install btsync and it did work perfect, I did intall the latest version from the dropbox of the dev. Did run it for 2-3 days, then I rebooted the NAS and after reboot btsync forgets the se...
devos
Jan 16, 2014Tutor
Did found out what the issue was, it's a bug on Mavericks in the SMB2.
If you do access a network driver with SMB2 under Mavericks, it's somehow change the permissions in the folders / files.
