niallryan
Jul 16, 2024Guide
Can I connect directly my MacBook Pro to NAS
Hi all, I am looking to see if it is possible to connect my MacBook Pro directly to my ReadyNAS Ultra 6 which would allow me to transfer TB's of files quickly rather than going through the network. ...
Jul 16, 2024Guru - Experienced User
The only way to connect to the Ultra is using ethernet. It is possible to set up a direct connection to the MacBook using one of the two ethernet ports on the MacBook. But it won't be any faster, so IMO not worth the trouble.
What speeds are you seeing for large file transfers? I don't own this model, but I think large-file transfer speeds should be in the 60-70 MB/s range.
