klidster
Jul 15, 2018Apprentice
Can I move Pro Business (RNDP6000) disks to an Ultra 6 Plus (RNDP600U)?
For years I've used an old ReadyNAS Pro Business system (RNDP6000) for periodic rsync backups of my 14TB+ video library. Unfortuately its power supply died a few days ago, so I picked up an inexpensi...
- Jul 16, 2018
Yes. You may wish to put a scratch disk in the Ultra 6 Plus, and check that the firmware on the unit is at least as recent as what was on the Pro Business. If it's not, update the firmware, verify the firmware update is successful (i.e. comes up fine after a reboot), then power down, remove the scratch disk and move your disks across (keep the order the same).
There are some posts on the community about replacing the PSU on a Pro Business (at your own risk).
Personally I would've recommended getting a new unit rather than a second hand unit. There's no warranty or support for second hand units. You can move disks from a RAIDiator-x86 system to one of our OS6 x86 systems (i.e. RN300 series, RN400 series, RN516, RN520 series, RN620 series, RN716X) following this procedure: ReadyNAS: Migrating disks from RAIDiator 4.2 to ReadyNAS OS 6 (x86) - though you'd need a place to backup your data to if you'd move your disks to an OS6 unit.
mdgm-ntgr
Jul 16, 2018NETGEAR Employee Retired
klidster
Jul 16, 2018Apprentice
Thanks, mdgm, for your prompt response. Since the Pro Business is dead I can't verify the firmware release, but I'm pretty sure its up-to-date so I'll just ensure the Ultra is current using a scratch disk as you indicated.
I looked into replacing the PSU and actually removed it preparing to get and install another. But researching it showed that it wasn't very straight-forward, simple, or even guaranteed to work. I considered a new unit as you mentioned, but this system was being used as more of a glorified rsync server and was only being turned on a few times a month to update the main movie server's backup. So for just a few hundred bucks I decided to pick up the used Ultra 6 Plus instead.
On a different note, I've been running ReadyNAS servers since the NV days, and I've been a member of these forums just as long. As issues have popped up over the years I've checked in here and always got excellent advice. And more often or not its been you, mdgm, that gave that prompt and good advice. I'd like to personally say I'm very grateful for all the help you've given over the years. So once again, thanks!
