castlekeep
Sep 05, 2012Aspirant
Can I reuse my NAS Duo disks in my PC
Hello. I have a Netgear NAS Duo V1 with two 1Gb drives installed. I'm going to change these soon for Two 2 Gb drives as I'm running out of disk space. :( I would like to reuse the 1Gb drives ...
castlekeep
Hello Herieo
Thank You for your reply.
A few mins ago I read on this forum that a windows PC would not show the disks in "My Computer" because the format is not compatible. If this is true then how do I reformat them, while installed in my Windows PC, so the PC can make use of them.
Sorry to sound dumb.
Connie
Connie
