drennman
May 31, 2014Aspirant
Can I upgrade my drives to 2 or 3 TB?
I currently have a ReadNas Duo with two 500 GB SATA drives. Can I upgrade these drives to 2 or 3 TB each? I guess I mean is there a limit on the size of a drive that you can use in the Duo? I ...
Jun 01, 2014Guru - Experienced User
drennman wrote: The partition log looks to be like 4 k sector partitions as I see "sectors of 1*512 bytes" in the partition.log.
Disk /dev/hde: 500.0 GB, 500097376256 bytes
255 heads, 63 sectors/track, 60800 cylinders, total 976752688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Look again at the guide - you need to verify that the start sectors are all divisible by 8.
[quote="http://www.rnasguide.com/2011/06/22/why-you-might-want-to-factory-reset-a-sparc-readynas/":38euybe5]If unsure if your disks are 4k sector aligned, download your logs (Status > Logs > Download all Logs), extract the zip contents and look at partition.log. If your disks are 4k sector aligned the entry for a disk should look something this (you can see the start sectors are divisible by 8, remember 4096 = 8 * 512, so 4k sector aligned disks are also 512-byte sector aligned):
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 976736335 486064152 5 Extended
/dev/hdc5 4608040 976736335 486064148 8e Linux LVM[/quote:38euybe5]"Start" is the 2nd field in the sample: 32, 4096032, 4608032, 4608040
look in services->installed add-ons. ReadyNAS remote will likely be preinstalled, so ignore that one.
drennman wrote: Dumb question #1. How do I tell if I have "addons?" I doubt I would as I don't recall doing anything of the sort.
There's no real point - 50 MB is not enough to be useful. So don't bother setting that.
drennman wrote: Dumb question #2. When backing up the config do I also want to include "Data Volumes - Save the files and folders in the data volumes. This is useful for transferring folder trees and default share contents. It is limited to a combined total of 50MB" as part of the config backup options?
