drennman
May 31, 2014Aspirant
Can I upgrade my drives to 2 or 3 TB?
I currently have a ReadNas Duo with two 500 GB SATA drives. Can I upgrade these drives to 2 or 3 TB each? I guess I mean is there a limit on the size of a drive that you can use in the Duo? I ...
chirpa
Jun 01, 2014Luminary
No point for the average home user. This was more for deploying many systems in SMB. You could setup initial directory structure, which the config backup would help create on multiple systems. If you already have data on the NAS, this is useless.
There's no real point - 50 MB is not enough to be useful. So don't bother setting that.
drennman wrote: Dumb question #2. When backing up the config do I also want to include "Data Volumes - Save the files and folders in the data volumes. This is useful for transferring folder trees and default share contents. It is limited to a combined total of 50MB" as part of the config backup options?
