drennman
May 31, 2014Aspirant
Can I upgrade my drives to 2 or 3 TB?
I currently have a ReadNas Duo with two 500 GB SATA drives. Can I upgrade these drives to 2 or 3 TB each? I guess I mean is there a limit on the size of a drive that you can use in the Duo? I ...
drennman
Jun 02, 2014Aspirant
Thank you again StephenB! Start values (as you assumed) are not divisible by 8 so I will follow your steps and do the factory reset on the new drives. I did install ReadyNAS Photo as an add-on but never used it so I can skip your step (e)?
Thank you Chirpa for more details on my Question #2.
Thanks!
Thanks!
