drennman
May 31, 2014Aspirant
Can I upgrade my drives to 2 or 3 TB?
I currently have a ReadNas Duo with two 500 GB SATA drives. Can I upgrade these drives to 2 or 3 TB each? I guess I mean is there a limit on the size of a drive that you can use in the Duo? I ...
Jun 03, 2014Guru - Experienced User
Yes, if you uninstall it before step b.
drennman wrote: ...I did install ReadyNAS Photo as an add-on but never used it so I can skip your step (e)?
Also, label the drives (by slot) as you remove them in (c). You can still reinstall them (NAS powered down) if needed, and the NAS will work as it does not.
