carlocki
Aug 06, 2022Luminary
cannot access anymore to nasnetgear
First this same problem https://community.netgear.com/t5/New-ReadyNAS-Users-General/DNS-error-message-6001010060-readycloud-login-and-admin-page/td-p/2246514 then I added to the ethernet paramters ...
carlocki
Oct 23, 2022Luminary
I keep loosing crediantial on pc so i have to reinstall everyday the OS on nas
it is very frustrating and it does not work
carlocki
Nov 30, 2022Luminary
I noticed that moving from dhcp to static ip put everything in a big mess. resetting dhcp let me enter in again
- StephenBNov 30, 2022Guru - Experienced User
Were you reserving the IP address in the router?
Or manually configuring an IP address in the NAS web ui?
- carlockiNov 30, 2022Luminary
now I set static ip inside the router and free dhcp inside the nas. maybe could work
- carlockiDec 01, 2022Luminary
RESUMING EVERYTHING
Now my router set the ip on a number and the nas in on DHCP and everything work. The only big issue it is If i change the admin password i cannot access anymore from pc to nas with the folders
this is the only issue right now. Mapping the router solved the request of password from windows to the nas.
I am scared to try to change admin password cause I won't to do a no os reinstall
