zekzek's avatar
zekzek
cannot access "data" folder from readynas web dashboard
Hello everyone, I have searched through the Netgear forums and also googled but not sure what I might be doing wrong. The "data" folder houses my Plex folders. I can access these Plex folders from w...
  • StephenB's avatar
    Mar 14, 2022
    Can you explain more on why you need to do this?
    zekzek wrote:
    1) is the "data" folder specifically hidden from the readynas web dashboard?
    Basically, yes.  On top of that, the plex files are in a hidden folder (along with the files for all the other apps).
    zekzek wrote:
    2) how is it that I am able to view and modify the subfolders within the "data" folder with Windows Explorer?
    Because Netgear has chosen to allow access to the data volume when you use NAS admin credentials.  If you weren't using those credentials, then you wouldn't be able to access the volume (or .apps).
    You do need to be careful when using that facility.
    zekzek wrote:
    I've run the share_lun_ui_fix.sh script in Terminal after logging in with root.
    As you found, that doesn't change this behavior.  As far as Netgear is concerned, it is intentional, and not something to be changed.
ProSupport for Business
