paschm
Oct 12, 2015Aspirant
Cannot access local admin page after first startup
Hello, I am not able to access my newly bought RN202, SN 45Y2535W003FC. I just connected the power cable and turned it on, however the power light doesn't stop flashing even after hours. The NAS c...
- Oct 12, 2015
Ok I figured out the solution by myself. Without a HDD inserted the NAS won't boot up correctly. As mentioned I already tried to insert a HDD and to make a factory reset afterwards. Now I saw that I didn't insert the HDD correctly. If the lock on the rack (the thing in which you put the HDD) is open then you can't insert it back in the case completely and the power und data connector don't connect. Maybe a little bit more detailed manual on this (for dummies like me) would be helpful. Argh...
paschm
- paschmOct 12, 2015Aspirant
Correction: If the lock on the rack (the thing in which you put the HDD) is already closed then you can't insert it back in the case completely
- StephenBOct 13, 2015Guru - Experienced User
There are plenty of details in the manual here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/RN_OS_6_Desktop_HW_UM_26March2015.pdf
Pages 96-103 show step by step disk insertion for both 2.5 and 3.5 inch disks, with plenty of pictures.
- paschmOct 13, 2015Aspirant
Ok, thanks for the hint, this should be sufficient
