Froglet0
May 10, 2020Aspirant
Cannot configure remote UPS
Recently aquired ReadyNAS 214 and moved the USB connection for my APC ES700 UPS from my old ReadyNAS 104 to the new RN214. I then tried to set up a remote UPS connection on my 104 to the UPS on the 2...
- May 12, 2020
Froglet0 wrote:
As the 214 is new can I raise this with Netgear support?
No harm in trying. You could also reverse the setup (connecting the UPS to the 104, and setting up remote monitoring on the RN214) as a test.
Although this is obvious, just in case - Did you remember to "enable network monitoring of attached UPS" on the RN214?
