MAHESH_HS
Nov 09, 2021Aspirant
CANNOT READ FILE PERMISSION DENIED
MAHESH_HS
We are trying to access from the $ share via built-in Administrator account. Initially it connects & pulls out some GB data afterwards results in error as
cannot read file 'file name' permission denied
Nov 09, 2021Guru - Experienced User
Are you saying that you want to back up a PC to the NAS using a built-in backup job from the PC's $ share?
- MAHESH_HSNov 10, 2021Aspirant
Actuallly we are pulling data from Windows 10 Pro machine, which has built-in C$,D$ Drive Shares out of which C$ is getting copied but D$ is resulting an error.
- StephenBNov 10, 2021Guru - Experienced User
As you likely know, some files/folders are locked down and can't be copied.
If it's not those, then you either need to adjust file permissions and/or sharing permissions on the PC, or change the credentials used on the ReadyNAS.
Or push the data from an account that has access, instead of pulling it.
- SandsharkNov 10, 2021Sensei
StephenB wrote:Or push the data from an account that has access, instead of pulling it.
Trust me, you'll save yourself a lot of headaches going this direction. Using something on the Windows side that uses Windows Shadow Copy is the only way to assure you have a coherent, complete backup.
