PaulLin
Mar 24, 2025Aspirant
cannot update antivirus defination
Support, Recently our NAS has indicate antivirus scanner definition file update failed due to download failure. Our Internet connection is ok Please advise any comment Many thanks Pa...
Mar 24, 2025Guru - Experienced User
What NAS model do you own, and what firmware is it running?
zero11
Oct 05, 2025Tutor
Mine too, three NAS running 6.10.9, two 314's and one Ultra4 Plus.
The last definition file is from September 29, 2025. What's the fix?
- StephenBOct 05, 2025Guru - Experienced User
The last definition file is from September 29, 2025. What's the fix?There is none. See my reply here:
- https://community.netgear.com/discussions/readynas-use/rn212-cannot-update-virus-definitions/2467133
