NARKOSIS
Nov 16, 2021Aspirant
Cant access folder structure beyond one level on readycloud.netgear.com
Good afternoon, We have a ReadyNAS 3138 (FW 6.10.5 Hotfix 1) and I've setup a cloud user. Assigned him the read/write permissions for specific folders and when he logs in on any browser, he sees...
Nov 16, 2021Guru - Experienced User
Did you try resetting the file permissions in the file access tab for the share(s)?
- SandsharkNov 17, 2021Sensei
If you add a user to share access who is not a member of a group that already has access, then you have to reset permissions for that user to have the proper rights for existing files and folders. It's why groups exist, but a lot of users don't know that and mostly ignore groups. Note, same applies if you add a group, but just that once.
- NARKOSISNov 17, 2021Aspirant
Oh I definitely have groups set up. He is able to access those specific folders in the office and on his cellphone through the readycloud app. It only doesn't work through a web browser. I just put him temporarily into the built-in admin group to see if that worked (it didn't). And even set the permissions to "everyone" temorarily and that didnt work either. I'll try resetting the permissions soon.
- StephenBNov 17, 2021Guru - Experienced User
Changing the permissions on the file access tab only affects the root folder of the share. If you want to change the permissions recursively to the existing files/folders, then you need to first change the settings, and then use the reset control.
