musselasse
Feb 25, 2025Aspirant
Can't connect to my ReadyNAS Duo v2
Sorry to bother you guys and girls, I try to connect my ReadyNAS Duo v2 with my home newwork and computer but nothing happens. I have WIn 11 and Intel Core i7-processor. 1) I bought my NAS in 2011...
Feb 25, 2025Guru - Experienced User
musselasse wrote:
2) My computer doesn't recognice the device; not with newwork cable nor USB.
USB won't work. Directly connecting the ethernet to the PC can be made to work, but does require some technical skill.
Connect the Duo to a router LAN port. Are you seeing the NAS show up in your router's device list?
When was the last time you successfully connected to your NAS?
musselasse wrote:
I try to connect my ReadyNAS Duo v2 with my home network and computer but nothing happens.
Are you certain this is a Duo v2? Does it say
- ReadyNAS Duo v2 on the front panel?
- or does it say ReadyNAS Duo on the front panel?
musselasse wrote:
wonder if Raidar 6.0 will work
RAIDar 6.5 will work. You will need Java, which you can get from here:
(BTW, you would need to install an older version of Java to use RAIDar 4.3.8)
