Syphon02
Jan 14, 2021Aspirant
Can't connect to NetGear ReadyNAS RND4000
So, hi! I have two NetGear ReadyNAS RND4000s, four drives each. They had bad firmware out of the box, but a factory reset later and they are up and running fine. All drives fine, 100% on both. ...
- Jan 14, 2021
Syphon02 wrote:
I've tried going through NetGear's ReadyCLOUD but it can't detect either box despite being directly plugged into my router.
ReadyCloud only works with OS-6 NAS - not with your legacy NAS.
Syphon02 wrote:
As far as I can tell I have everything set up right for them in the FrontView webpage, but I'm clearly missing something.
One thing is that with Windows 10 you need to go into "turn windows features on or off" and enable the SMB 1/CIFS client on the PC.
Your path in Windows Explorer looks incorrect. Try entering \\nas-ip-address into the address bar - being careful to use the correct slash direction. Of course use the real NAS IP address.
