shaffke
Jun 07, 2013Follower
Cant detect disc. Possible to recover it?
I got a Netgear Readynas Duo v2. Had to turn it of and move it today, but when I turned it on again it started beeping and it could not find the disc. The beeping stops after a while, but there is a...
Jun 07, 2013Guru - Experienced User
Try http://www.diskinternals.com/linux-reader/ It should let you see the contents of the disk on the PC.
For the voodoo tricks, you could try support.netgear.com But I suggest making a backup first.
If you want to recover your data, make sure the NAS is powered down when you re-insert your drives.
