tonyvee1973
Jul 15, 2021Aspirant
cant enter tech support mode on readynas dui v1
Hi All First post here as my faithfl readynas is playing up. I rmeoved my drives as wasnt going to use it anymore, few months later trying to access disks on windows machine to repurpose them but s...
Jul 15, 2021Guru - Experienced User
tonyvee1973 wrote:
the readynas doesnt seem to want to go into tech support mode where i think i need to be to get this done?
Are you booting into tech support mode using the procedure on pages 15-16 here: https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
- tonyvee1973Jul 15, 2021AspirantHi and thanks for the reply. Yes doing that and got in after entering user snd pass. but don’t know what to enter now to unlock the hard disks.
Just trying a factory reset with both supposed bad disks in and will leave overnight. Any idea though what commands I use in tech support mode to j lock the hdd?- StephenBJul 15, 2021Guru - Experienced User
Just trying a factory reset with both supposed bad disks in and will leave overnight. Any idea though what commands I use in tech support mode to j lock the hdd?It should be
hdparm --security-unlock NETGEAR /dev/sdx
of course using the correct drive for sdx
