tonyvee1973
Jul 15, 2021Aspirant
cant enter tech support mode on readynas dui v1
Hi All First post here as my faithfl readynas is playing up. I rmeoved my drives as wasnt going to use it anymore, few months later trying to access disks on windows machine to repurpose them but s...
tonyvee1973
Hi and thanks for the reply. Yes doing that and got in after entering user snd pass. but don’t know what to enter now to unlock the hard disks.
Just trying a factory reset with both supposed bad disks in and will leave overnight. Any idea though what commands I use in tech support mode to j lock the hdd?
Jul 15, 2021Guru - Experienced User
It should be
hdparm --security-unlock NETGEAR /dev/sdx
of course using the correct drive for sdx
