Silv08
Jul 28, 2016Follower
Can't set up my Readynas 10200
I am trying to set up my new Readynas 10200 with a MacBook Pro, but when I get to the screen where I am supposed to name my readynas and set the time zone, I get a 'Device Communication Error' that t...
- Aug 16, 2016
Thank you for your reply! I just solve it by myself.
I login as admin in local mode ( 192.168.1.xxx) and then I went to Cloud tab and turn on the ReadyCloud addon( default was OFF), now everything works pretty perfectly! Thx again!
Jul 28, 2016Guru - Experienced User
Did you try leaving the name alone, and just changing the time zone?
JennC
Jul 28, 2016NETGEAR Employee Retired
Hello Silv08,
What FW version? Are you getting error message after changing the hostname? If so, did you try entering http:// followed by the LAN IP address of the NAS in the address bar to get back to the NAS admin page?
Welcome to the community!
