Silv08
Jul 28, 2016Follower
Can't set up my Readynas 10200
I am trying to set up my new Readynas 10200 with a MacBook Pro, but when I get to the screen where I am supposed to name my readynas and set the time zone, I get a 'Device Communication Error' that t...
- Aug 16, 2016
Thank you for your reply! I just solve it by myself.
I login as admin in local mode ( 192.168.1.xxx) and then I went to Cloud tab and turn on the ReadyCloud addon( default was OFF), now everything works pretty perfectly! Thx again!
JennC
Aug 02, 2016NETGEAR Employee Retired
Hello Silv08,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
MrGamerChoi
Aug 15, 2016Tutor
Hello Moderator!
New ReadyNas 102 user here. I just bought this machine a day ago and finished up all the cable and power setup and went though the setting. Unfortunately like as OP's problem, I got stucked when it tells me to do the last step (pree the backup button). After like 3 minutes, it automatic cancel my setup.
I tried to power off and on, changing different computer, switching different browser...etc and have no luck with it. Some that got my attention is that even I power off / disconnect my NAS it still status that it found a new ReadyNas on the readycloud page and asks me to set it up.
After some research, I have tried to download the RAIDar software and complete the data syncing thing, turn out it says my NAS status is GREAT and it can even identify my two HDDs that installed on it, "My Computer" shows up the Syncing folder (I'm using Win10)
After all, I can't manage my NAS though my browser.
Here's some information about my Setup:
NETGEAR ReadyNAS 102
firmware 6.2.4
Tp-Link WDR7500
Windows 10 PC x2
Macbook x1
- mdgm-ntgrAug 15, 2016NETGEAR Employee Retired
You should be able to click setup in RAIDar and get to the local web admin page.
The default credentials are admin/password.
Please update the system to 6.5.1. ReadyCLOUD now requires 6.5.x and later.
- MrGamerChoiAug 16, 2016Tutor
THANK YOU! It works!
However, the readycloud still doesn't work ( currently you have no registered or shared devices ) but the locl ip connection (192.168.1.xxx) works!
- mdgm-ntgrAug 16, 2016NETGEAR Employee Retired
What do you see for the service status on the CLOUD tab of the local admin account. In the user list is your MyNETGEAR account showing or your old account?
