q3d
Aug 23, 2021Aspirant
Case Sensitive SMB Shares
Currently it appears SMB case sensitive shares are (still) set to being case insensitive. There is a requirement to have SMB shares case sensitive in (mostly) *nix environment. The main reason i...
- Aug 23, 2021
Normally you put your custom settings in /etc/frontview/samba/smb.conf.overrides (which should be empty by default). The ReadyNAS application will overwrite the other files.
Aug 23, 2021Guru - Experienced User
Sandshark
Aug 23, 2021Sensei
As best I can tell, /etc/frontview/samba/addons/addons.conf is also not overwritten. Just remember that the last directive supersedes any before it if there is a conflict and that the system sees the files as one big file with the include files inserted where the include statement is.
