JanHussaarts2
Dec 21, 2020Luminary
Certificates after upgrade to 6.10.4
I have my own domain and run Owncloud on my NAS. After upgrading to 6.10.4 my Let's Encrypt certificate solution is no longer working. The NAS is offering its own local certificate to any client tr...
JanHussaarts2
When I looked into the /etc/frontview/apache folder I noticed all changes I had made were gone. Files replaced by the original ones I think.
So I stopped appache, recreated the ssl.conf file and created a new chain.pem and restarted apache. Everything seemed to be working properly again.
There is one problem. In the near future I cannot use certbot-auto anymore. I wil have to install snapd (whatever...) and do some configuration. Me not being a linux expert, that is going to be a challenge. Can't Netgear supply some simple instructions for the use of real certificates?
Sandshark
Feb 06, 2021Sensei
I put a suggestion for an easy way to install certificates in the Idea Exchange years ago, even suggesting LetsEncrypt as a good option.. It has a few kudos, but nothing but crickets from Netgear.
- JanHussaarts2Feb 07, 2021Luminary
In the Lets Encrypt community many people are complaining about the obligation to use snapd.
It seems te be an immature and unstable product that is not suited for production environments.
CertBot is maintained by another party.
I suppose the only way to keep using Lets Encrypt is the manual method:-(
