DavidJG
Nov 23, 2016Aspirant
Changing a disk for a larger one
I have a NAS 314 with Xraid (Raid5). I have three disks installed 2 x 4TB and 1 x 1TB. My question is:- Can I change the 1 x 1TB ONLY to a 4TB to enlarge storage for Vertical Expansion? ...
- Dec 03, 2016
Thanks very much.
I changed the disk for a larger one, and after several hours of rebuilding hey presto! all is working fine with the greater capacity I now need.
Wonderful!!
Dec 01, 2016Guru - Experienced User
DavidJG wrote:
so, if I gracefully power down the system, change the 1 x 1TB for a 4TB, and power up, will the system rebuild ALL the data from the former 1 x 1TB onto the 4TB disk?
You have 2x4TB + 1TB and are using XRAID, correct? If so, you can replace the 1 TB with a 4 TB. There will be no data loss if the already installed 4 TB drives are healthy.
Though Netgear always does recommend a backup (and I agree with them on that).
FWIW you don't need to power down - you can remove the 1 TB drive and insert the new 4 TB one with the system running.
DavidJG
Dec 03, 2016Aspirant
Thanks very much.
Wonderful!!
- FramerVDec 04, 2016NETGEAR Employee Retired
Hi DavidJG,
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
