gpaolo
Jul 06, 2020Luminary
Changing all disks on RN314
Hi all,
one of the disk on the RN314 at my parents' home failed and I have just noticed that all disks there have >55k hours of on time, so... maybe it's time for some renewal :)
Oddly (but that must have been me) there are four relatively small disks (2x 500GB + 2x 1TB) in raid 5 configuration, but although I was able to make a second backup of everything also after the disk failure, I would feel more comfortable to put the two new disks in raid 1, since space is not really an issue.
If I remove all old disks and plug the new two disks I imagine that I will lose also the partition with the OS6 and it will be reinstalled starting from scratch -something that I would like to avoid.
So my question is, what should be the right way to do the work?
Should I remove the two 500GB disks (one of those is the broken one), plug the two new disks, create a new raid-1 volume on the new disks, then unplug the other old two? Is the NAS supposed to move the OS6 to the new ones for some reason?
I have made a backup of the configuration, but I would guess it's not going to contain also the configuration for the other applications running on the NAS, like Plex, VPN, etc., right?
Thanks for any suggestion!
Personally I tend to run the disks until I see some signs of failing. Though of course others will replace them on a schedule.
Normally the process would be to replace the disks one at a time, and wait for the system to resync before moving on to the next. But that would require you to replace all four.
The other way is to back up the files, power down the NAS and remove all four disks (labeling by slot). Then put in the two new disks, and power on the NAS, doing a factory install. Reconfigure the NAS (creating any user accounts, shares, installing any apps, etc), and restore the files from the backup. OS-6 will be reinstalled from scratch (as you note in your post). Is there a reason why this is a problem?
There's no way to shift from 4-disk XRAID to RAID-1 via the web ui. There is a fairly risky way to do that with ssh/linux command line.
- gpaoloLuminary
StephenB wrote:Personally I tend to run the disks until I see some signs of failing. Though of course others will replace them on a schedule.
Well, one died from one moment to the other, with no previous advice. Now I can't even see it's details any more, so it's dead dead. I see that they all have the same age, so... I prefer to avoid disasters. Even if I have backup (I have learned my lessons).
Well, one is that I have to do all the process remotely connected to one of the PC, the other is just... time. It's not my NAS, so I need to find out how I configured everything long time ago and redo it.
Ok I think I might have not explained myself properly here. It's not that I want to shift from XRAID to RAID-1, it's more like, I would like to get rid of XRAID and start a brand new RAID-1 without being forced to do a factory reset because taking all the disks off would mean to lose the copy of OS6.
I don't know if it's a bit more clear in this way...
- SandsharkSensei
You can save the configuration from the System/Settings page. Then restoring it on the newly factory defaulted NAS will take care of everything except the actual data and apps. If there are any apps, you do need to restore them before restoring the config backup. In the long run, that will be cleaner and faster, since you already have the data backed up for restoration. Oh, and if you use user home folders, the user must log in via ReadyCloud or SMB (depending on the type of user) for the user folder to be created. Then you can restore that data.
You could leave the RAID5 degraded to leave an empty bay to be filled by a new drive on which to create a new JBOD volume, then destroy or export the original volume, remove the remaining old drives, add the second new one, then add redundancy to the JBOD to get RAID1. But that process has many potential pitfalls which could push you into the first scenario to recover. As with starting over, destroying or exporting the main volume does not move apps though it is supposed to (and usually does) move their location to the new volume. This option's only plus is that you can copy data from the original RAID directly to the new one instead of using an external backup.
For the future, you may want to look into a VPN (I use ZeroTier, which is not a traditional VPN) to make it easier to do remote administration. You could then log directly into the NAS instead of going through a PC on the remote network.
