InterClaw
Jan 09, 2013Aspirant
CIFS freezes, SMART errors the culprit?
I was gonna post about having freezes when copying files around using CIFS, but then I checked the SMART data of the drives and I think there's been some changes since last time I did that. I don't kn...
InterClaw
Jan 13, 2013Aspirant
I've moved my data over and the new NAS (running 3TB WD Reds, WD30EFRX) seems to be doing very well. :) So I though I'd initiate the first RMA on the 4th drive.
The problem is the etailer where I bought it does not carry the RE4-GP WD2002FYPS anymore. I'm guessing my replacement drive(s) will be the RE4 WD2003FYYS instead. These have the standard 7200 rpm spindle speed though, whereas the GP drives spin at like 5900 rpm.
Do you think I'd have problems with a combination of WD2002FYPS and WD2003FYYS?
Btw, both types are on the Pro Pioneer HCL though (if you look past the note about firmware on the FYPS... but that's another story...).
- Jan 17, 2024Retired_Member
