Kaktus_2016
Jan 17, 2016Aspirant
Cloning problem?
Hi, I have bought a ReadyNAS Duo v2 (RND2000v2) and a ReadyNAS RN10200. Both NASes have two harddrives and all the four harddrives are identical. I have downloaded Readynas replicate for the Rea...
Kaktus_2016
Hi Mdgm,
The ReadyNAS Duo v2 has firmware version 5.3.11 and the ReadyNAS RN10200 has firmware version 6.4.1.
Kind regards
Henrik
mdgm-ntgr
Jan 18, 2016NETGEAR Employee Retired
Can you send me your logs from each unit (see the Sending Logs link in my sig)?
- mdgm-ntgrJan 20, 2016NETGEAR Employee Retired
Could you try disabling anti-virus on the 102 and see if that makes any difference?
What kind of Replicate job is it that you setup? Could you email me some screenshots of the settings of the job?- Kaktus_2016Jan 20, 2016Aspirant
Hi mdgm,
Thanks for your help. I tried to disable the antivirus, but it did not make any difference.
My dream is to have the two NAS to clone each other. I have tried to setup both Backup system and Backup data jobs, but I haven't been able to get any of them to function.
Kind regards
Henrik
- StephenBJan 21, 2016Guru - Experienced User
I don't believe you can do 2-way sync with replicate (or the built in backup either).
What you can do is have some shares on system A that are backed up to system B, and other shares on system B that are backed up to System A.
But you can't create a common share, where changes on either A or B are applied to the remote NAS.
Also, the built in backup jobs on the web ui don't use replicate (or remote). So that may be what is confusing you. I agree with mdgm that you need to post some screen shots (or PM them to him) so we can see more clearly what you are actually doing.
