Knewman
Mar 13, 2018Aspirant
Cloning ? of GS108T settings to GS724T
Maybe I don't have the correct search term, but I just purchased a 24 port switch (GS724T) as I have outgrown the 8 port GS108T. I want to know if there is a way to transfer all of the setup info from on too the other so I don't have to go through the 3 days of setup I went through with the 8 port switch. Maybe the answer is to unplug something and just daisy chain? Would that mean everything going onto the new switch would be on a different subnet? I know just enough about all of this stuff to be a danger to myself and others, any assistance would be most appreciated.
Hi Knewman,
Welcome to our community! :)
It depends on how your GS108T was setup. If it doesn't have any configuration like you just plug and play it before, then you can just do the same thing. But if you have other configs, then you can just copy it. There is no way that we can transfer or use the config file as the hardware version is not the same.
- JohnC_VNETGEAR Employee Retired
Hi Knewman,
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- KnewmanAspirant
GS724Tv4 setup was easier than ever. I just started from scratch and added a LAG and plugged everything in one item at a time. Only had one hiccup with a networked printer that got confused. Other than that, no issues. Thanks for making this easy. No kidding it took 2 hours and was done.
Thanks
Kevin
