Knewman
Mar 13, 2018Aspirant
Cloning ? of GS108T settings to GS724T
Maybe I don't have the correct search term, but I just purchased a 24 port switch (GS724T) as I have outgrown the 8 port GS108T. I want to know if there is a way to transfer all of the setup info fro...
- Mar 14, 2018
Hi Knewman,
Welcome to our community! :)
It depends on how your GS108T was setup. If it doesn't have any configuration like you just plug and play it before, then you can just do the same thing. But if you have other configs, then you can just copy it. There is no way that we can transfer or use the config file as the hardware version is not the same.
JohnC_V
Mar 14, 2018NETGEAR Employee Retired
Hi Knewman,
