aks-2
Sep 20, 2020Apprentice
Community login failures
In recent weeks I have had problems logging in to this community site, I'm using Firefox 80.0.1, Windows 7, and follow the login button as usual. However, I am getting an error:
The page isn't redirecting properly An error occurred during a connection to www.netgear.com. This problem can sometimes be caused by disabling or refusing to accept cookies.
The way I have found that does work is to visit www.netgear.com first and login to my account there, then go to community.netgear.com.
This only started happening over the recent 2-3 weeks. Any suggestions?
I'm not seeing this on my own system (though it is running Windows 10).
Does it happen if you try it from a private window?
- aks-2Apprentice
From my Windows 10 machine, with Firefox 79.0, logging in was fine. I'll experiment some more.
Thanks
