937carrera_2's avatar
937carrera_2
Community username
I have just had to change my password (no longer meets requirements, not logged in for a couple of years) and when I came to login it asked me for a username.   It wouldn't allow me to use 937carre...
  • 937carrera's avatar
    937carrera
    Jan 13, 2017
    OK, got it sorted. The "reactivate your account" link didn't seem to be working properly, so I did a bit of lateral thinking and went through the standard reset password approach, and as you can see, I now have access to my original posting profile.
    Now to get the Nas > Nas backup problem resolved  (I did read your helpful guide mgdm before starting the job last night, even though my task was much simpler) :smileyhappy:
    https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Folder-Timestamps/m-p/1208087#U1208087
ProSupport for Business
