Gord_in_Toronto
Dec 03, 2018Aspirant
Connecting RN212 to Cyber Power CP850AVRLCD UPS
Can I just plug it in? I don't need any management features from the NAS device.
Sandshark
Dec 03, 2018Sensei
Of course you can. But why would you not want management features from the NAS? Should a power outage be long enough that the UPS is going to shut down, you really want the NAS to shut down gracefully.
Gord_in_Toronto
Dec 08, 2018Aspirant
Thanks.
I'm currently using the Cyber Power POWERPANEL Personal software to shutdown my PC via the USB connection. I see no obvious way to gracefully shutown both the PC and the NAS..
Gord
- StephenBDec 09, 2018Guru - Experienced User
In my experience, it's more important to shut down the NAS cleanly - so if you need to choose, I'd connect the NAS to the USB port.
The NAS uses the Network UPS tools. There is a beta package available for Windows here: https://networkupstools.org/download.html#_binary_packages
It is possible to monitor the CyberPower status over the network (through the NAS) - but doing that also requires that any equipment on the network path (switch or router) be protected by the same UPS.
- Gord_in_TorontoDec 10, 2018Aspirant
Thanks for the additional info and insight.
I'll spend some time trying to make some sense out of this; including looking at package in the link you provided.
