jelockwood1's avatar
Sep 22, 2014
Convince me to stay with ReadyNAS
NetGear seem to be neglecting the ReadyNAS product line. Apparently even the top most models the 3220 and 4220 are only SATA II based whereas everyone else making computers or servers or NAS boxes has long ago moved on to SATA III. Worse still NetGear continue to fail to add support for authenticating via an LDAP server and limit authentication to either local accounts or an Active Directory server. As far as I can see every other NAS maker does support LDAP including QNAP and Synology in particular. As a more esoteric issue, none of the ReadyNAS models can host Virtual Machines (they can only store the VM disk files). QNAP for example seem able to actually run VMs within their servers. NetGear are also proving incredibly slow to approve new hard drives, they have a very few 4TB drives listed but no 5TB or 6TB drives at all. QNAP have a lot more 4TB drives listed and already also list some 5TB and 6TB drives. The older ReadyNAS models also do not support SMB2 even though a compatible version of SAMBA has been available for ages - it is not necessary to use SAMBA4 to implement SMB2, SMB2 support was added in SAMBA 3.6. The newer OS 6 models do support SMB2, this affects speed.
So while I have been considering getting a ReadyNAS 3220 or a 4220 which might be a fairer comparison to QNAPs equivalent TS-EC1279u-RP model I am wondering if people can provide any reasons to stay with ReadyNAS rather than jumping ship. Here are some items to consider.
    - RAID expansion, how does ReadyNAS with its X-RAID compare to QNAP or Synology?
    - File system expansion (assuming RAID expansion is possible), I get the impression that the new(er) OS 6 ReadyNAS models with BTRFS can pretty much expand unlimited now unlike the older ReadyNAS models which had expansion limits above which you had to factory reset, is this correct? Again what about the competition?
    - Speed, issues like SATA III, SMB2, etc.
    - Reliability, other than hard disk failures my current flock of ReadyNAS units have been very reliable, any views on the reliability of QNAP and Synology?
    - Support for LDAP authentication?
    - Support for forked-daapd?
    - Support for Spotlight indexing?
    - Any other comments?
ProSupport for Business
