Bangali
Dec 21, 2015Aspirant
Copying data across from old to new NAS
Hi all, New to community so forgive any mistakes! I have recently bought a RN204 to replace my WD Live Duo as I likes the features. Now, I want to migrate all my files across and was wondering if t...
Bangali
Dec 23, 2015Aspirant
Thanks for the quick reply StephenB.. I have had a look but I think I can only create a 'safepoint' of the whole WD NAS. There is a way of selecting specific shares, but that needs ssh access and knowledge of 'Rsync' which I am not familiar with.. Is there any way I can just take out the HDD from the WD and put it in the ReadyNAS? I have it set up in RAID format so would that just copy everything over? Sorry if it's a silly question, I am not too well versed in this!
Dec 23, 2015Guru - Experienced User
No, it is formatted completely differently.
You create the backup job from the ReadyNAS web ui, not the WD. If you can access the shares from Windows, you can transfer the data w/o rsync.
The source would be "remote".
Host is the IP address of the WD NAS
Protocol is remote (windows timestamp)
login/password can probably be left blank (but can be the user logon/password you use with the WD).
The destination is "local", and you select the destination share you are copying to.
- BangaliDec 23, 2015Aspirant
Thanks, I will try this when I get home tonight and let you know!
