jrover
Nov 19, 2019Guide
Corrupted /dev/md0 in OS6.10.2 ReadyNAS Ultra 6 starts in safe mode
Hi All, Recently the ReadyNAS Ultra 6 I've been running 6.10.1 prompted me to upgrade to 6.10.2. Although I was doing other copy operations, I decided to queue it up for the next time I rebooted....
jrover
Nov 19, 2019Guide
Hi StephenB ,
Thanks for your advice. I did pull all my disks, add a spare single drive and did a factory reset and the NAS built a new volume and functioning installation --- so I know that will work. I'll spend more time backing up absolutely everything try the btrfs check --repair /dev/md0 and if that doesn't help, I'll do a factory reset with the 4 original drives installed.
Thanks
eduj7im
Feb 10, 2020Aspirant
Hi Jrover,
I have a similar issue.
Would appreciate if you could shed some light how to backup some files on tech-support mode?
This is my Thread
- jroverFeb 10, 2020Guide
Hi eduj7im
I followed these directions to telnet to my system via tech support mode:
(keep reading the comments and you'll see some additional context for the following set of commands in the replies, in case the below don't work for you)
then I typed:
/> start_raids
(assuming you don't have a directory named, "MY_NAS_VOL" at root)
/> mkdir /MY_NAS_VOL
(if you list the devices in /dev (ls /dev), you should have /dev/md0 which is your root partition and /dev/md127 which is your data at least these were the names on my Readynas Ultra 6+)
/> mount /dev/md127 /MY_NAS_VOL
Now mount the USB drive, these instructions should help:
https://askubuntu.com/questions/37767/how-to-access-a-usb-flash-drive-from-the-terminal
/> lsblk
/> mkdir /MY_USB_VOL
/> mount /dev/sdbX /MY_USB_VOL
(replace 'X' with the /dev/sdb1 or /dev/sdb2, etc. you get from the lsblk command)
Note: I used a drive already partitioned for FAT32 and under 2TB in order to be mounted and visible. (Here are some formatting instructions in case you have a fresh drive with no partitions https://www.redips.net/linux/create-fat32-usb-drive/ If you have trouble mounting, the partition may be unrecognized or too big ---- not sure if there are limitations in tech support mode on format-types)
Copy the files you want from /MY_NAS_VOL to /MY_USB_VOL
/> cp -rp /MY_NAS_VOL/data /MY_USB_VOL/data
That command attempts to keep permissions / date-time-stamps / etc.
Hope this helps.
- eduj7imFeb 10, 2020Aspirant
Thank you so much jrover. I'll study this and do it.
I'll let you know whats the outcome. I really appreciate it
- StephenBFeb 10, 2020Guru - Experienced User
After you boot up in tech support mode, you access the CLI with telnet (not ssh). The login is root, the password is infr8ntdebug
Use this sequence to mount the data volume in tech support mode:
# start_raids
# btrfs device scan
# btrfs fi show
# mount /dev/md127 /dataThe steps jrover gave you will fail if the data volume has multiple RAID groups (e.g., if the volume was ever vertically expanded or ever had unequal size disks).
If the USB drive is formated as NTFS, then you will need to mount it with mount –t ufsd I'm not sure if that works in tech support mode or not.
