DCFluX
Nov 29, 2021Aspirant
Corrupted EEPROM on ReadyNAS 2100
I was attempting to upgrade a RedayNAS 2100 from RAIDar 4.2.31 to 6 and I discovered that I actually have the v1 hardware that doesn't support 6. (V1 aparently uses a full size DIMM memory stick) ...
Sandshark
Nov 30, 2021Sensei
The VPD file is unique to your NAS (it includes the serial number) and is encrypted. Only Netgear can create them.
You did use an OS4.2.x style USB recovery, correct? And did the process seem to go right (unit turned off at completion)? If not, then try another USB drive. The legacy machines can be quite finicky about the drive you use. OS6 conversion preserves the VPD, so I'm not sure why the upgrade process, though it would fail to boot on that hardware, would cause the VPD to be deleted or corrupted.
- DCFluXNov 30, 2021AspirantYes I used a 2GB thumb drive that I keep around for firmware updates because I've had good luck with it working on everything I've plugged it in to like test equipment
Held down backup for 15 seconds while pressing power on and unit seemed to boot and shut it's self off after about 3-4 minutes.
