Rick_D457
Jun 22, 2019Initiate
Readynas Pro 6 EEPROM issue
Hello
I have upgraded my Pro 6 (RNDP600E) to OS6 without any issues, it was stable and worked fine. Hoping to upgrade RAM, I bought old DRAM chips on Ebay, the exact model that was confirmed to work, in one of the forums.
After plugging in the new RAM, the system stopped booting, stuck with the "ReadyNAS" green message. I plugged in the old RAM chip, but it made no difference. Out of options, I did the USB Boot Recovery (for OS 4) and apparently messed up the EEPROM.
At the moment, the system looks like it boots, but the Model section in RAIDar is garbled and when I connect via a browser, I only get a part of the homepage, mostly the edges (currently the "RAIDiator-x86-4.2.31-downgrade" unofficial image installed - I hoped the downgrade would make a difference).
Is there any way to make the EEPROM work again?
I would be very grateful for any help, after reinstalling different OSes several times I am out of ideas how to make it work. I hope there is a way to recover it.
Thank you! -Richard
Thanks for your patience. It should have booted with the correct VPD now please confirm it to me :)
We needed to encode the correct VPD that is why I asked for it to be on SDM
Regards
- tony359Apprentice
I'm not a super expert on the issue but I have the same unit.
Did you try doing a factory reset or chosing a "reinstall OS" on the boot options - assuming it gets to that stage?
You can try Reinstall OS first (if you have data that you want to keep) and then factory reset (that will wipe your data). Disclaimer: you may end up losing data anyway.
I upgraded the RAM and CPU years ago and don't remember having issues but at that time I was using a single HDD for testing and did not have any problems if a reset was needed.
The corrupted model number rings a bell though. Keep us posted.
- Marc_VNETGEAR Employee Retired
Regards
- Rick_D457Initiate
Marc_V, thank you very much for your help. It works as new. Living happily ever after. Thank you.
