owentje1
Jul 22, 2009Aspirant
Corsair VS1GSDS333 1GB
I'm using this in my NV+ and it works fine. Completed a few memtests.
- marmat78AspirantI'm also using it without any problems, in a Duo.
- RicounetZapAspirantConfirmed with 2 memory test on my DUO
- bhfAspirantUpgraded my NV+ and ran 4 memory tests, OK.
- mdgm-ntgrNETGEAR Employee Retired
bhf wrote: Upgraded my NV+ and ran 4 memory tests, OK.
You need to update your sig (original section). 256GB RAM? I think you meant 256MB RAM - brubaccaAspirantI just put this in my DUO and ran 2 memory test. Everything is A.O.K!
- WonderdudeAspirantDecided to snag one of these from Amazon. Can anyone tell a noob how to do the memory test?
- rworneAspirantMy module came in from Amazon, went right in and works perfectly.
Wonderdude wrote: Decided to snag one of these from Amazon. Can anyone tell a noob how to do the memory test?
Finally got around to slapping it into the Duo today. Seems to be working fine. I still haven't found out how to do the memory test. Can anyone help me out? - dbott67Guide
Wonderdude wrote: Wonderdude wrote: Decided to snag one of these from Amazon. Can anyone tell a noob how to do the memory test?
faq.php#Is_there_a_way_I_can_verify_if_my_memory_is_good%3F - Marcel_XAspirantI replaced the 256MB SODIMM for a Corsair VS1GSDS333 1GB without problems.
However, the anticipated performance boost in Frontview and NFS transfers is barely noticeable. :(
