patdman81
Jul 04, 2022Tutor
Could not delete share due to snapshot deletion failure.
I'm trying to delete a share and keep getting an error. Could not delete share due to snapshot deletion failure. Code: 1004030000 I have a RNDU6000 running OS v6.10.7 Any thoughts on how to res...
- Jul 06, 2022
patdman81 wrote:
I have not been able to delete this share via the web UI.
First I would double-check that the volume is not in read-only status.
patdman81 wrote:
Any thoughts which command to use?
Log in as root, using the admin password.
Then list the snapshots for the share with
# btrfs subvolume list -s /data | grep SHARENAMEsubstituting the real sharename for the placeholder of course.
Then try deleting them one at a time using
# btrfs subvolume delete -c <path>Where <path> is the full path to the snapshot - something like /data/SHARENAME/.snapshot/NUMBER/snapshot
Note the first command won't include the /data/ bit, but the second command definitely needs it.
After the snapshots are sucessfully deleted, delete the main share from the admin web ui. If you get an error deleting a snapshot, then post it here.
patdman81
Jul 05, 2022Tutor
I do indeed have ssh enabled.
Patrick.
Jul 06, 2022Guru - Experienced User
- patdman81Jul 06, 2022Tutor
That did the trick!
Thanks 🙂
