jpm102
Apr 28, 2016Tutor
Creating a folder with restricted access
Hello everyone from a relative NetGear newbie. I have an RN104, which is fitted with 4 x 3Tb WD RED drives, configured as one large RAID5 volume. It has firmware version 6.4.2. The device is...
- Apr 29, 2016
Many thanks everyone for your help!
Clearly the issue lies at the Windows client end, rather than the RN104.
By using the 'Stored Usernames and Passwords' list in Windows 10 (C:\Windows\System32\rundll32.exe keymgr.dll, KRShowKeyMgr), I've managed to set the correct level of access on the 'Restricted' share I'd set up on NELLY.
I think this issue is now resolved.
Thanks again :smileyhappy:
James
Retired_Member
Apr 29, 2016
StephenB wrote:
jak0lantash wrote:Alternatively, you can close all Explorer windows et destroy the samba session with a net use command (net use //blablabla /delete /y)
Sure- a batch file that does net use * /delete would remove any sessions. But its easy to forget to run it.
We surely agree on that one.
It's better to create two Windows accounts anyway, for that purpose and others.
That's why, it's "alternatively" ;)
jpm102
Apr 29, 2016Tutor
James
