miogpsrocks
Mar 28, 2019Tutor
Creating A New Volume requires dedicated hard drives?
Does creating a new Volume require dedicated drives to be assign to that volume or can they be from the same array as the first volume?
You know how with Windows, you can take a single hard dr...
Mar 28, 2019Guru - Experienced User
The manual is here: https://www.netgear.com/images/support/WP_ReadyNAS%20FlexRAID%20Optimization%20Guide_18May17.pdf
In principle the underlying RAID tools would allow you to create multiple volumes on the same set of drives. However, as far as I can see the admin ui doesn't let you do it.
