Equinox1
Mar 22, 2015Guide
Daisychain the Pro 6
Hi everybody, The ReadyNAS Pro 6 has 2 ethernet ports on the back, and I would to use them in "pass-through" mode. Where I want to set it up, I only have one ethernet socket available, and I would...
chicchaz
Mar 24, 2015Aspirant
is it possible to use the eSata or USB3 ports to connect two units to the same computer? i got a new one and want to double check the configuration against the older unit. also, it would be handy to have some of the data from one NAS to another without using a local hard drive as a go-between.
sorry to hijack your thread, but isn't the latter why you'd want to network two units together?
cheers,
-charlie
cheers,
-charlie
