Equinox1
Mar 22, 2015Guide
Daisychain the Pro 6
Hi everybody, The ReadyNAS Pro 6 has 2 ethernet ports on the back, and I would to use them in "pass-through" mode. Where I want to set it up, I only have one ethernet socket available, and I would...
mdgm-ntgr
Mar 24, 2015NETGEAR Employee Retired
Not sure if a way could be made to hack it to do it, but even if so I wouldn't recommend it. It's not designed for it.
As for trying to use eSATA or USB3, the NAS is not a peripheral. The eSATA and USB3 ports are not for connecting the NAS to your computer.
The second network port can be used for bonding etc.
