Equinox1
Mar 22, 2015Guide
Daisychain the Pro 6
Hi everybody, The ReadyNAS Pro 6 has 2 ethernet ports on the back, and I would to use them in "pass-through" mode. Where I want to set it up, I only have one ethernet socket available, and I would...
itsjasper
Mar 25, 2015Luminary
Ah, but it is actually a piece of hardware that you DO need.... and a switch is cheap, low-energy, and is the universally-recognized means to connect more than two devices together.
Also, you CAN team both NICs together on a Pro 6, so you are mistaken on the speed point too.
I'd also like to point out that your SONOS example given is actually a non-standard ethernet implementation, though I can see the benefit in that instance. Theres not a not of devices out there that have such an implementation.
